2001 YZ426 - 3rd gear problem - what´s wrong????
10 replies to this topic
  • jespertheil
Posted May 29, 2004 - 06:40 AM
After a jump today my bike suddently starts to slip in 3rd gear. I felt right away, but what is wrong?
All the other gears works great, but if i put it in 3rd it pops in and out of gear. I´m thinking maybe have landed on the gearpedal and ended up bending a shift fork, is that it?
  • Hamish
Posted May 29, 2004 - 04:37 PM
more than likely you have rounded out of broken a dog on the gear. A bent fork will normally show itself in other gears aswell. My Wr did a similar thing, but it was jumping out of fifth. The culpret was a bent fork and (which was probably caused by) a dog missing off 3rd gear (which engages fifth). Either way, it's time to split the cases for further investigation.
  • indiandunes
Posted May 30, 2004 - 04:48 AM
Welcome to the blown 3rd gear club!
  • MAD_POTTER
Posted May 30, 2004 - 12:41 PM
Here's my experience
http://www.thumperta...true#Post914473
It's not too difficult of a job, just follow the manual!
KC
  • tool
Posted May 30, 2004 - 03:46 PM
"It's not too difficult of a job, just follow the manual!"
and for god's sake use a torque wrench, on every bolt, and retorque the 3 screws on the CB gear. stupid screws. :thumbsup:
  • Tassie_Stephen
Posted May 30, 2004 - 07:34 PM
My YZ did the same thing but in fifth. Check the shift fork and fifth gear. The shift fork should have sharp edges on it, not rounded at all. Apparently its a common problem with the YZ. I asked Yamaha Australia about it and they said they knew nothing of it, but when I recieved my new 3rd,5th, and shift fork the new gears were 'beefed up'.
  • jespertheil
Posted June 03, 2004 - 01:00 AM
Just did the case splitting and my problem was exactly the same!
3rd, 5th and a new shiftfork..
300 USD $$ and i´m back in business..
  • jespertheil
Posted June 03, 2004 - 10:43 AM
http://frip.dk/jespertheil/2.JPG
http://frip.dk/jespertheil/3.JPG
  • MAD_POTTER
Posted June 03, 2004 - 07:29 PM
Yep, that's what mine looked like.
I better start using the clutch more often.
KC
  • jespertheil
Posted June 03, 2004 - 11:44 PM
Is that why??
I must admit that i have done a lot of shifting without clutch... :thumbsup:
  • MAD_POTTER
Posted June 06, 2004 - 07:00 PM
That's what I've been told.
Most of the time I'm just trying to hold on so I just back off the throttle for half a second and shift!
KC
  • 5 replies
Motocross
  • Hot  491 replies
  • Hot  36 replies
  • Hot  47 replies
  • Hot  79 replies
