Best way to clean clutch steels
4 replies to this topic
  • pmh971
Posted May 28, 2004 - 07:42 AM
Hey Guys, I was wondering if anyone had any goods ways to clean up the steel plates in the clutch. I ordered new friction plates (steels were out of stock) and needed to clean up the steels. Thanks
  • skthom2320
Posted May 28, 2004 - 09:05 AM
I would replace them all together.
Order them from North County Yamaha or Yamaha of Troy.
  • Hamish
Posted May 28, 2004 - 11:37 AM
check the warp on the steel plates using a sheet of glass and a set of feeler guages. If they are in spec find someone who has a bead blaster and give them a hit with that. The bead blast will give them a nice 'as new' grippy finish.
  • dooweb2
Posted May 28, 2004 - 04:50 PM
bead blast if you must.(Id replace them as a set. do not sand blast that heats up the plates and distorts them
  • gonzo
Posted May 28, 2004 - 05:11 PM
Agreed. They are only 25 bucks to replace them all. Call BSY at 888-BSY-FAST
  • 0 replies
  • Hot  47 replies
  • Hot  36 replies
  • Hot  50 replies
