Compression is weird. HELP!
1 reply to this topic
  • Polar_Bear
Posted June 09, 2002 - 06:59 PM
K, I ride a 426 (obviously), it is an 01. I ride it a lot. At least once a week, sometimes 3! Well my motorcycle doesnt have any compression anymore when it is cold and it is really hard to start. But once I start it and it warms up, the compression comes back and it is easy to start again. But whenever it is cold there is no compression and it is hard as hell to start. SO>>> Do I need a new top end, or just rings?
>>>>> Is there something wrong with my valves?
Let me know!
  • Guest_mxrider426_*
Posted June 09, 2002 - 07:34 PM
Sounds like you have stuck valve syndrome. Have you ever had the head apart? Did you say that the bike started before or after the compression retuned? Try this, after you warm it up, stop it and put the piston in top dead center (so that the valves are closed and no tension is on the springs), and let it cool down. Then see if it still has compression.
[ June 09, 2002: Message edited by: mxrider426 ]
  • 9 replies
  • Hot  33 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
  • 0 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
