Replacement rad slightly wider?
2 replies to this topic
  • BoffoRider
Posted May 25, 2004 - 07:43 AM
I had to replace my right rad after doing some damage to it. I purchased a new one from a dealer and when I put it on I noticed it was slightly larger than the original because my plastic fins won't fasten on anymore because of the increased width. Was I given the wrong rad? If so, I won't be able to return it because I purchased it before the winter and never had the opportunity to replace it until now.
Thanks in advance,
  • sirthumpalot
Posted May 26, 2004 - 12:44 AM
Only way to tell is check the part number.
  • PBDBLUE
Posted May 26, 2004 - 03:10 AM
Are you sure you put the rubber grommets in the right way? If I recall one side may be thicker than the other.
Motocross
  • Hot  491 replies
  • Hot  50 replies
  • 10 replies
  • 0 replies
