oil change interval
5 replies to this topic
  • Vanilla_Gorilla
Posted June 08, 2002 - 01:31 PM
what is a realistic oil change interval, and how many oil changes should my filter last?
  • Guest_Guest_*
Posted June 08, 2002 - 04:21 PM
Call me ANAL but...........
I change mine the night b4 a DEZ race then race and change it the next day.
I then practice for the week and change it the night b4 again! :D
CALL ME ANAL
but it will surely not hurt. :)
I check the filter everyother time and have rarely needed to rinse it out.
  • PK
Posted June 08, 2002 - 04:53 PM
I guess it another consideration is what kind of oil you use. I use Castrol 20-50 non-synthetic and I change it every other ride. I clean my oil filter every other oil change. Air filter every ride. My oil filters last quite a while. I recently tossed 2 out because I set my toolbox on them and squished em'. Whenever you pull one out make sure they are still in good shape and the mesh isn't seperating from the housing. I see in your signature you have a full factory bike. Do you have a dry sump or wet sump motor? If it's been changed over to a wet sump, I would change after every ride....
Good luck,
PK
02 426
  • Vanilla_Gorilla
Posted June 08, 2002 - 05:57 PM
getting a wet suump conversion in a few days
  • PK
Posted June 08, 2002 - 06:05 PM
Better buy some oil. :)
  • Vanilla_Gorilla
Posted June 09, 2002 - 03:33 AM
if i did the wet sump conversion, do you think it would be safe if i changed the oil every other ride or every 3? cuz every 5 rides is what you should do witht he dry sump according to the book
  • 10 replies
  • Hot  36 replies
  • Hot  50 replies
