motor misses
8 replies to this topic
  • chais1
Posted May 24, 2004 - 01:37 AM
2nd 3rd motor misses down low but open throttle and all is sweet road registed in australia so have to go slow in traffic this is where problem was discovered :thumbsup:
  • Indy_WR450
Posted May 24, 2004 - 03:33 AM
Sounds like jetting? Ignition? Only 2nd and 3rd gear? Need more info to help. :thumbsup:
  • lightstorm
Posted May 24, 2004 - 04:06 AM
Drop the needle one notch (lift clip 1 notch )in the carby!
  • sabin
Posted May 24, 2004 - 08:05 PM
Byke is designed for racing e.g. accelerate-brake-accelerate-brake.... if you ride it with steady trottle at mid revs it misses. Do what other sugjested.
  • chais1
Posted May 24, 2004 - 08:23 PM
thanks for the input fella,s will start riding it like i stole it :thumbsup: :awww:
  • simch
Posted May 25, 2004 - 11:55 AM
Dropping the needle will weaken it. Sounds more like its running a bit weak, hence the hunting and missing, and on full gas, with the accelerator pump squirting extra fuel in, it runs ok. I would try (indeed I will be this weekend cos my UK one is the same) raising the needle (ie lowering the clip) to richen it a bit.
  • chais1
Posted May 25, 2004 - 12:07 PM
cheers bloke will try that today lowering the clip :thumbsup:
  • lightstorm
Posted May 25, 2004 - 09:10 PM
The prob is that it is running rich believe it or not.
RAISE the clip to LOWER the needle to lean it off a bit.
  • chais1
Posted May 30, 2004 - 04:56 PM
motor running wicked now thanks 4 the input :thumbsup:
