fork oil level ??
4 replies to this topic
  • davidvak
Posted June 06, 2002 - 09:18 PM
what is the fork oil level for yz400f 99` ?
i think in the book it is 130mm max but
somebody told me that it can be even 100mm max...
is that tru ???
  • RIDEPATE
Posted June 06, 2002 - 02:04 PM
david, true,i'm running mine @ 100mm ahhhhhhhhh the plushness...........jimbo
  • DaveJ
Posted June 07, 2002 - 07:33 AM
David,
A high fork oil level (a low number) means the fork will progressively get firmer as it moves further into the stroke. Aka, more bottoming resistance.
A cheap form of medical insurance when learning how to jump.
However, more oil also means the front end will not dive as much when entering a corner. The bike will push or seem top heavy. Not a good thing.
As always, it's a compromise.
DaveJ
  • mike_dean
Posted June 07, 2002 - 07:48 AM
My forks were done at MX-Tech and set at 95mm, works great with their valving. mike
  • gal
Posted June 09, 2002 - 06:21 AM
hi david,
whats up man? here in israel its fu@#$ng hot, it has been 42 c today n yesterday.
ok so as an answer to your question - the manual says 80mm-150mm , so if u want it 2 b hareder go up to 85mm, in 5mm intervals and check what is best 4 u
  • Hot  47 replies
  • 0 replies
  • Hot  36 replies
