XR 650 Fuel Filter
2 replies to this topic
  • sven
Posted May 21, 2004 - 12:46 PM
One Of My Buddies Says There's No Way To Put
A Fuel Filter On His XR 650!? Would Someone
Please Talk Him Thru It!
Thanks!
  • irondude
Posted May 21, 2004 - 02:42 PM
Most XR650R's have a fuel filter--its built into the petcock and rises into the fuel tank. It can get clogged over time and its a good idea to check it once every year or so...
If you need a second fuel filter--not sure why ya would--but if you do need one, you can just splice it in between the carb and the petcock. I run a second tank-the Acerbis under the seat tank, and i have a large filter under my seat between the two tanks. Right next to all those wires...
  • Buds3rd
Posted May 21, 2004 - 02:55 PM
The best way to put a fuel filter on a 650R is to first install a TM40 Mikuni. The fuel inlet for that carb is further from the petcock and allows space for a filter. The stock carb is hopeless-------------
  • 3 replies
  • Hot  60 replies
  • 4 replies
  • Hot  35 replies
  • 9 replies
