Good or Bad
2 replies to this topic
  • Wrfrk
Posted May 19, 2004 - 09:15 AM
So I found the other day that I had been running my '00 400 with the hot start button in the out position. During the time I was running the bike it was also not running as good as normal, I'm sure b/c it was a bit lean. Anyhow, do you think doing this could cause any long term problems?
Posted May 19, 2004 - 09:43 AM
In effect you were running very lean. If you only did it for a short time (like a couple of miles) I doubt it will have any long term effect. If you were to continue to run it that way most likely you would burn an exhaust valve.
  • Frostbite
Posted May 19, 2004 - 10:05 AM
The hot idle circuit would affect low rpm's but the little bit of extra shouldn't affect the mixture at riding speeds.
