2004 450F MAIN JET MIX UP
7 replies to this topic
  • Vet28
Posted May 19, 2004 - 06:40 AM
My 2004 YZ450 CAME WITH A 172 MAIN. MY 2003 HAD A 165. BOTH MANUALS SAY 165. DID SOMEONE JUST GRAB A 172 'CAUSE THEY WERE IN A HURRY, OR IS THE MANUAL WRONG? ANYONE ELSE CHECK THERE'S LATELY?
MY BIKE LIKES TO STALL IN TIGHT CORNERS. DOES ADJUSTING THE FUEL SCREW HELP? OTHER OPTION ARE A 49 TOOTH REAR, ACCELERATOR PUMP ADJUSTMENT?
HELP
  • gonzo
Posted May 19, 2004 - 06:52 AM
I would go back to the 165 main and check the screw to make sure it's spec.
  • Sean_McCutcheon
Posted May 19, 2004 - 07:17 AM
Mine came with a 165
  • brian389
Posted May 19, 2004 - 11:31 AM
Turn up your idle a little higher than normal and it will prevent stalling, as well as getting the fuel screw right. I put a power-now on mine, and it starts easier, and has more punch off the bottom. I'm at 7000 feet altitude so very different jetting up here.
  • jetnurse
Posted May 21, 2004 - 05:55 PM
Did you purchase you bike from canada?
they come with a 42 pilot and 172 main
jetnurse
  • Vet28
Posted May 25, 2004 - 06:11 AM
You are a smart man.
I actually threw in a 170 yesterday and backed up the cam on my accelerator pump by 1/4 turn. I have the Jardine RT4 pipe and they recommend going up a size on the main. On my 2003 it came with a 165 and I went to 168. Now, my 2004 comes with a 172 and I went to 170. Were there carb/motor changes that warranted Yamaha going up 7 jet sizes?
Thanks for your help. :thumbsup:
  • Le_Racer
Posted May 25, 2004 - 10:53 AM
Salut!The manual say a 42 pilot, 4th clip on the needle and 165 main, just like my 2003, but when I checked my 2004 it had a 45 pilot, 3rd clip on the needle and 175 main.
I didn't run it stock, but with my ported head, Hindle exhaust, GYTR flywheel and running Pro Racing Fuel MK IV, I run a 48 pilot, 4th clip and a 178 main.
With the same set up on my 2003 I ran 42 pilot, 5th clip and 165 main. The 2004 run quite a bit better, it's crisper and doesn't stall easily.
Ciao!
Guy
  • Vet28
Posted May 26, 2004 - 06:13 AM
Hey...I was out there last Sep and really loved your province. Great people, great scenery and awesome MX tracks.
Did you have a bog, or stall off idle under load (like a heavy acceleration out of a corner)? I did. I went from the stock 172 to a 170. I haven't ridden it much yet with the new jet. The manual says try a smaller main if you have that bog/stall problem. If that doesn't work I'm going 48 & 175.
Vet28 :thumbsup:
  • 0 replies
  • On January 15, 2017
  • Hot  38 replies
  • 5 replies
  • Hot  47 replies
