Is a 98 zy400f cylinder the same as a 00 wr400f
2 replies to this topic
  • R_Little
Posted April 28, 2004 - 08:13 AM
I hope so as I just bought one for a big bore kit?
Also I'm gonna try to put an 04 yz450 shock and linkage on the same 00wr.
Anyone know if it will work, I know the shock is longer and the linkage is different, but I wonder if it will work together?
Thanks
  • MrBlahh
Posted April 28, 2004 - 09:03 AM
I dont know :thumbsup:
What big bore kit you going with?
The best route that I've heard, is take a 426 cylinder, bore it out 2mm to 444cc and replated
then take your crank, and have a 426 rod put on it, and use a standard 426cc 2mm over piston
that's what I have, 13:1 mad power, only I use a standard 400 rod, with a custom piston
  • MN_Kevin
Posted April 28, 2004 - 11:18 AM
How did you come across this custom pin?
[I am using Wiseco's 420 kit using the standard connecting rod.]
