Installing a new timing chain.??
6 replies to this topic
  • YZFan
Posted April 27, 2004 - 02:41 PM
Is there anyway to set the crankshaft on top dead center with out the fly wheel and the side cover on?? I have been all over the manual and cant find it. Are there any other timing marks?? I am installing the 450 cam and a new timing chain and dont want to reassemble everything just to check it out. Thanks for any help
  • Lukejt
Posted April 27, 2004 - 02:47 PM
Just take the plastic screwed in plugs out of the cover. Then you can put a wrench on the crank, and see what position it's in. I know that's in the manual, and it's easy to do.
Lukejt
  • tctrailrider
Posted April 27, 2004 - 03:25 PM
I don't think so. Install the chain on the crank shaft. Secure the chain from the top so it doesn't fall into the tunnel. Reinstall the magneto, flywheel and side case. Set it at TDC through the inspection hole. Install the intake cam so it lines up properly and set the exhaust off the intake. The flywheel has a key so its self aligning on the crank.
  • skthom2320
Posted April 27, 2004 - 03:45 PM
Well, if it was close to begin with you could just put a straw in the spark plug hole to find the highest point of the piston.
  • YZFan
Posted April 27, 2004 - 04:22 PM
While I was fighting with the chain to remove it the crank turned. I was just wanting to know if there was any other way to set the timing with out putting all back together. Thanks for the info.
  • tctrailrider
Posted April 27, 2004 - 04:43 PM
That doesn't matter. The crank can be rotated to any position with the chain off or on. The only important part is to find TDC once you have the new chain on and then set the cams properly. You will need to put the side case back on to do that.
  • Matt96xr6
Posted April 27, 2004 - 04:49 PM
setting the timing involves the camshafts in relation to the crankshaft.
So really put the piston at TDC. Then just fit up the rotor to see if the marks correlate correctly if you were to look through the site hole (12 oclock position). If not, turn the crank 180*.
To find out the top, remove the tank and sparkplug. Insert a long torx or phillips screwdriver down the spark plug hole. Find the highest point, TOP. Pretty simple. From there, leave the crank alone and then align the cams accordingly since the engine will now be at TDC.
  • Hot  50 replies
  • Hot  28 replies
  • On January 15, 2017
  • Hot  113 replies
