2 replies to this topic
  • clodoveo
Posted May 28, 2002 - 04:56 AM
I have a 2001 426f and the plugs seem to be constantly fouling. Does any one have any ideas on how fix the problem.
  • sirthumpalot
Posted May 28, 2002 - 05:31 AM
Changing brands of gasoline completely solved my plug fouling with my '01. I was using Mobil which fouled plugs. Chevron and Sunoco works OK for me now. Other people have had other solutions but I hope this one works for you (it's the easiest). :)
  • yznvegas
Posted May 28, 2002 - 05:48 AM
The first thing that comes to mind is you are experiencing a rich condition. When are you fouling plugs, when you are starting the bike and it is cold or when the bike is warm? You might need to go a step leaner on your jetting because as the temparature warms up, it will create a rich condition and the opposite is true when the weather starts cooling off again. The reason being, hot air is less dense than cold air. :)
  • 0 replies
  • Hot  33 replies
  • 9 replies
  • Hot  36 replies
