Engine question
11 replies to this topic
  • YZFLORIDA
Posted May 27, 2002 - 03:00 AM
I changed my oil today.First time i have had metal shavings in the oil filter housing, what do i look for first? Clutch,gears? please help :) :D
  • John_Lorenz
Posted May 27, 2002 - 03:05 AM
YZflorida
yz is this the first oil change on your 99 400 ?
if so then WHHYYYYYYYYYYYYYYYYY SO LATE have you owned the bike new
if its a new bike perfectly normal for the couple of oil changes. Just clean or replace the filter. Advise get a magnetic oil drail plug, this will drw the metal to the bottom and allow the alluminum to be caught by the filter. Make sure you clean the strainer also.....
I still have small bits of al-uminum in my filter. Most likely the clutch
The YZ is just sheading aluminum skim. Unless its excessive dont worry about it....
If its the first change on the 99, man engine tear down for sure in my opinion, look at cams, tranny, bearings all the guts
Ego
[ May 27, 2002: Message edited by: EgoAhole ]
  • Fastest1
Posted May 27, 2002 - 06:39 AM
Hey A**hole just like I thought, you probably have a hard time understanding what the words really mean. Yz said it was the first time he has seen metal in his filter, not the first time he changed his oil! Metal is usually in the oil filters of these bikes as it is always a fresh post about it. Do they really have access to the net in the "pen"? How do you have time to respond to every F#$%*ing post. Shut up and ride! Cya :) :D :D
  • yznvegas
Posted May 27, 2002 - 06:44 AM
Egodumbhole, re-read the post, it is the first time he found shavings, not the first time he changed the oil... :)
To answer the question, it is perfectly normal to find shavings in the filter, that is what the filter is there for, to catch contaminants that would other wise harm the internal parts of your engine.
  • YZFLORIDA
Posted May 27, 2002 - 12:25 PM
Thanks fastest and yzn I feel better that it is normal wear. I change the oil @ every 6 hours of use
. thanks guys
I rode all day today at crooms and everything ran as usual very fast
  • Fryboy
Posted May 27, 2002 - 05:43 PM
Ego..... Don't ya just feel the love in here?
Dayyyyum why all the hostility?
P.S. Peace, Love, Happiness
  • sirthumpalot
Posted May 28, 2002 - 12:19 AM
Hey YZFlorida, where are you located in FL? I'm not familiar with the town that you have listed, are you north of okeechobee?
  • John_Lorenz
Posted May 28, 2002 - 02:43 AM
Fryboy
I dont mind, just a couple of bugs caught in the web.
I have crapped bigger turds, then them :)
[ May 28, 2002: Message edited by: EgoAhole ]
  • Shawn_Mc
Posted May 28, 2002 - 07:58 AM
YzFLORIDA you might want to check the clutch basket and HUB. I had the same deal with the shavings, then I started to get a little more material than before, but not what I would say is a lot. It turned out that the steel insert in the clutch hub had come loose and was allowing the hub to flop around and still work. The whole clutch assemble rides on that spine, so if its loose, the entire assembly will move around. Mine was flopping enough to touch the clutch cover. Id look, its free.
  • YZFLORIDA
Posted May 28, 2002 - 10:50 AM
Sirthump Valrico is just east of tampa
  • sirthumpalot
Posted May 28, 2002 - 02:46 PM
OK you're way up north. :) Shoot me an email if you're ever down south as far as okeechobee or melbourne!
  • YZFLORIDA
Posted May 29, 2002 - 01:51 AM
Sirthump my son and i were down in Clewiston about 2 weeks ago to do the FTR Harescrambles evnt.Iused to live in FT. MYERS, Clewiston was a great race and very hot.
  • 0 replies
  • Hot  36 replies
  • Hot  28 replies
