Hot Start Lever and rpms?
3 replies to this topic
  • YamaMonty925
Posted April 25, 2004 - 02:43 PM
Hey guys,
Question about the hot start lever. If the bike is running and warmed up and I push the hot start lever in, my rpms will rise because....?
Thanks in advance.
  • PBDBLUE
Posted April 25, 2004 - 03:26 PM
The rpm's rise because you making the mixture leaner. Sort of like having a vacuum leak.
  • Hamish
Posted April 25, 2004 - 04:12 PM
dont u mean pull the lever out??? In is off, out is on.
Leaner=higher idle rpm
  • YamaMonty925
Posted April 26, 2004 - 03:51 AM
Oh, I put one of the aftermarket lever's on it that changes the setup from "forefinger pull" to "thumb push".
I asked because at some point many brain cells ago I thought I remembered reading that if you were too lean/rich the hot start lever could help you figure out which way you were off.
I'm pretty certain my setup is good (168main, 48pj in Supermoto trim-Jardine Pipe, opened airbox, YZ cam etc) but wanted ask anyway.
Thanks.
