Installing Bearings
4 replies to this topic
  • RoosterBooster
Posted May 23, 2002 - 08:13 PM
I have had my YZ426 for about a year so after reading about the lack of grease from the factory and that I should have already greased several parts I decided to take apart the linkage in the swingarm and was all set to grease it up as I read.
Once I got the assembly apart which was completly bone dry. Several of the bearing are shot. I have them out and new ones will be here tomorrow. I wondering if there is a specific way to install them so I am sure I dont damage them. I was planning on using a socket and tapping them into the "Dog bone"
Any advice is welcomed!!
  • jbird
Posted May 24, 2002 - 03:10 AM
I made the same mistake on a previous bike. I just used a bench vise and a socket as a press to push them in. If you had easy access to a hydrolic press this would be the way to go. Another trick is to put the bearings in the freezer for a couple hours to "shrink" them a little before installation.
Anyway, just go slow and I'm sure like me you will never make the mistake of not greasing the linkage again---
Jon
  • bigdrtrdr
Posted May 25, 2002 - 07:18 AM
in adition to freezing the bearing sleeves. Put some heat on the linkage parts and they will go in much easier. good luck.
  • John_Lorenz
Posted May 25, 2002 - 07:28 AM
Place the bearings in a plastic bag an put them in the freezer over night.
With a butain torch heat the outer area of the bearing race for a few minutes 3 - 4 minutes.
At that point just drop the bearing dirctly in, no grease needed, nothing. The bearing will slip in and set.
then using a rubber mallet and a peice of wood that fits the bearing, Tap the bearing into place....
[ May 25, 2002: Message edited by: EgoAhole ]
  • Fireball
Posted May 25, 2002 - 05:47 PM
What is rarer than platinum and gold in Japan?
Locktite and Grease!!! seems there is none available there
  • Hot  113 replies
  • Hot  36 replies
  • 9 replies
