Help me out (yz426 jetting) newbie
8 replies to this topic
  • Jamo
Posted May 23, 2002 - 06:51 AM
My Buddy recently purchased and installed a white brother e-series silencer (stock header) and a uni aftermarket air filter for his 2001 yz462. :)
The bike now seems to have exchanged alot of the bottom and mid range that it had stock for a wild kick in the top end. :D
He is running stock jetting and no disks.
My questions are, in order to achieve more power in the bottom and mid range.
What jetting changes should he make (starting point, cause we are lost)?
How many disk should he run with your recommended jetting?
thanx
Benny
  • John_Lorenz
Posted May 23, 2002 - 06:53 AM
AAAAHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
another jetting question
AARARARRRRRRGggggggggggggghhhhh
Search read learn
Welcome though glad I could help :)
  • yznvegas
Posted May 23, 2002 - 07:22 AM
The reason your freind is seeing more top end is because there is much less back pressure with the aftermarket exhaust. Any time you restrict an exhaust system you will see gains in torque and bottom end, the opposite is true if you open it up.
My suggestion would be to have him experiment with the disks to provide some more backpressure in the exhaust. This will provide a base to start from, than start jetting.
Ego, this is not another jetting question by the way. Your responses are for the most part stupid and don't add anything to board, take a break.
  • yzrider02
Posted May 23, 2002 - 07:24 AM
If you take all the disks off you will loose back pressure. This will result is a loss in bottom end with gain in top end. Start with 12 disks ( I think White Brothers recommends this) with your stock jetting and see how it runs. You can then add and remove disks to taylor to your likes. Removing and adding disks will also effect your jetting.
  • John_Lorenz
Posted May 23, 2002 - 07:31 AM
Yznvegas
Who asked you anyway?
PLUS READ NUM NUT
[ May 23, 2002: Message edited by: EgoAhole ]
  • yznvegas
Posted May 23, 2002 - 08:15 AM
Again, num nuts, it's a back pressure issue FIRST and than a jetting question.
It doesn't matter, your response still holds no relevance. That seems to be a pattern for you, just typing in crap responses. You still haven't thanked me for that invoice I gave you through your p.m.
  • John_Lorenz
Posted May 23, 2002 - 08:46 AM
I take it that were not lovers any more Ehhh YZ :D
Ya know I am real sorry that I make no sense to ya, real sorry we cant be friends, and real sorry you are narrow minded.
Anyway I am no wait I am not SORRY
Man get a life go to a nevada cat house or something dude, your coils are twisted to tight...
Besides that blah, blah blah blah
The only back pressure her is between ye ears :D
XOXOXO
Ego
Ya know thinking about this I was wong yer right I should flog myself for being a NumNut too
Question is what should you do for being so judge"MENTAL"
Waaaa-Wa-Wa-huuuuWAAAAAAAAAAAAAAAAAAAAAAAAAAA :)
  • Shawn_Mc
Posted May 23, 2002 - 12:21 PM
I assume you mean no extra discs. because if you had no discs the end cap would seal off the pipe, and she aint gonna run like that I gaurantee it.
Im betting you didnt loose any on bottom, it just picked up a bunch on top.
If thats the only mod you have made, about half a turn out on the fuel screw and up one size on the main and you should be really close to perfect, assuming it was right before you started.
  • Jamo
Posted May 23, 2002 - 01:15 PM
wow thanx to the guys that tried to help me ... this site is really going where all the others go
Motocross
  • Hot  491 replies
  • 5 replies
  • Hot  33 replies
