Blueing on top of crank.......Normal?
6 replies to this topic
  • thumpinscott
Posted April 23, 2004 - 12:52 PM
Is this a normal find? I am going through the trans and top end, should I replace the rod and bearings as well? Posted Image
  • MN_Kevin
Posted April 23, 2004 - 01:37 PM
blue colour is ABSOLUTYELY NORMAL.
I asked the same thing 2 years ago.
  • thumpinscott
Posted April 23, 2004 - 02:42 PM
Thanks, I saw blue, and was singing the blues thinking that it must have burned up a bearing.
  • SXP
Posted April 23, 2004 - 03:36 PM
Second Kevin above. Brings back memories - I just completed a complete engine rebuild (top and bottom).
Where in SoCal are you? I'm in HB, and would be happy to lend a hand if you need it.
  • thumpinscott
Posted April 23, 2004 - 04:39 PM
I'm out in the 909, Redlands. If I need a hand I will absolutely get in touch, it's my first 4 stroke rebuild, but seems straight forward.
Not sure what piston to go with, wiseco 95 mm or 97mm, 12.5:1 or 13.5:1. I need to decide soon though.
My 5th gear was skipping so it was time.
  • SXP
Posted April 23, 2004 - 04:50 PM
Call Eric Gorr (see www.ericgorr.com). He's a wealth of info and very approachable and patient with answering questions.
  • Hamish
Posted April 23, 2004 - 10:10 PM
the blue is from the heat applied to the crank web during manufacturing where the crabkpin is pressed in. When I did my g/box I didnt do the rod/bearing, but that was due to a lack of $$$. Depends how many hrs the bike has done and how much $$ u want to spend. It's cheaper 2 do it now that it is after it's punched a hole in the cases :)
Hamish
  • On January 15, 2017
  • 0 replies
