Sproket gearing question?
9 replies to this topic
  • mikev7
Posted April 23, 2004 - 02:38 AM
I own a 2000 YZ426 and i want to get a little more top speed out of it. Will i get more speed by making the front sproket 1 tooth bigger, or the rear sproket 1 tooth smaller? I want the smallest adjustment being that 1st gear on this bike is allready tall. :)
  • Fly-nBri
Posted April 23, 2004 - 02:46 AM
If you do a search on this subject you will see a ton of info on it. But the smallest adjustment would be going 1 tooth bigger on the rear I believe. I tooth up front equals 3 teeth on the rear. :)
  • mikev7
Posted April 23, 2004 - 02:56 AM
Dosent one tooth smaller on the rear make more top end? Would one tooth smaller on the rear be a lot of difference?
  • revolucien
Posted April 23, 2004 - 03:05 AM
yes, one tooth smaller on the back is to bump top end and no, not a large difference
  • bigc
Posted April 23, 2004 - 04:00 AM
If you do a search on this subject you will see a ton of info on it. But the smallest adjustment would be going 1 tooth bigger on the rear I believe. I tooth up front equals 3 teeth on the rear. :D
nope got it backwards,smaller front is same as adding a bigger rear,equals lower gearing.Want to go faster, go bigger in front or smaller in back. :)
  • b-bike
Posted April 23, 2004 - 06:44 AM
bigc has it correct.
I wanted to make my YZ a woods warrior and I did so by going up 3 teeth on the rear (stock=49 now=52).
If the effect your looking for is a "slight" improvement in top end speed, go to a 48 tooth rear.
Boyd
  • mikev7
Posted April 23, 2004 - 07:11 AM
The stock front sproket is 14t, would you suggest going up to a 15 on the front. Or maby decreasing the rear by 2 teeth?
  • rbsdsu
Posted April 23, 2004 - 08:56 AM
If you are going to do the back then go by 2 teeth, you will probably not even notice the difference with just 1 tooth! On the other hand if you do the front which is much cheaper then just do 1 tooth, I finally found my best ratio at 15 - 48
  • mikev7
Posted April 23, 2004 - 10:18 AM
Ok thx, i'll try 15-48.
  • rbsdsu
Posted April 23, 2004 - 10:57 AM
Give it a try you might like it, you might not but you can always go back!
Good Luck!
  • 9 replies
  • On Yesterday, 06:20 PM
Motocross
  • Hot  491 replies
  • Hot  47 replies
