YZ400 Hotter Plug
6 replies to this topic
  • gonzo
Posted May 21, 2002 - 05:23 PM
I was wondering if anyone could tell me a hotter plug that I could use for the YZ400. Stock is a CR8E.
Thanks,
Alex
  • Mark_Cantrell
Posted May 21, 2002 - 06:07 PM
I hope no one does. 8's are hot enough. An EK may not foul as easily. Some prefer the Iridium plugs. But don't go hotter.
mwc
  • strack
Posted May 21, 2002 - 06:23 PM
I agree with mark, i don't know if it hurts to use a hotter plug but If you want to there is a cr7e. Try the cr8ek, it works good and doesnt foul near as easily.
__________________________________________________
98 yz400
[ May 21, 2002: Message edited by: strack ]
  • Mark_Cantrell
Posted May 22, 2002 - 01:09 AM
Strack,
I got some bad gas Monday. Ego will comment on that in a minute. Anyway, Monday evening I went through two plugs (CR8Es). They fouled black but different than rich fouling. Looked like flat enamel black.
I picked up a box of CR8Es before going riding last night (upcoming group ride). While I was there, I got a EK and EIX(?), just for grins. The new CR8E lasted about three laps (1.6 mile laps), the first one was an observation lap. Then I put in the heavy iron, the CR8EIX(?). It lasted probably 5 laps. Then I put on the EK. I ran hard about 2 1/2 hours (ran through the rest of the tank of gas, at least down to reserver, that's a lot of riding) and it's still in there.
I am overlean just to prove a point. 162 main, 35 pilot, FHN#3. The fouling was not rich.
In fairness, mostly on the EK, I was cutting the lower part of the track where I was harder on the gas (practicing changing attitude in air over a big but safe tabletop). That may have been the determining factor. But 8E, 3 laps. EIX 5 laps. EK energizer bunny.
Good luck,
mwc
  • JAHEY2
Posted May 22, 2002 - 02:40 AM
I use a CR8Ek and they work great, I haven't fouled one in awhile.
  • John_Lorenz
Posted May 22, 2002 - 02:44 AM
Somone Say "BAD GAS" :D
Unless ya want to burn a hole in your piston you should not place a hotter plug into the bike....
Long term this will damage and eventually burn a hole in the piston (IF YOUR JETTING IS TO LEAN).
Again, I dont understand why I see so many people with plugs just giving up the ghost. I have had two plugs in my 00 Since I have owned it in Jan of 02. I replaced the first becouse I just wanted to no reason. Now that plug is in my sons 02 250f running fine...
I think the suggestion of "BAD GAS :D " may be valid, I have never gotten BAD GAS, Well Except when I eat at That TacoRia before I ride :)
Thanks Mark for starting me up :D
  • vznx1w
Posted May 22, 2002 - 02:52 AM
Gonzo,
A hotter plug (CR7E)is an effective option for combating plug fouling and will work well if you're riding in conditions that don't allow sustained wide-open throttle: woods, trails, tight mx tracks. I have run a "7" extensively with no problems.
WARNING: If you opt for the hotter plug and take your bike to the desert, flat track racing, or long fire roads--any place where you can keep it pinned in 5th--you risk melting a piston. This happens when the high combustion temps turn the CR7E into a "glow plug" which initiates destructive detonation/preignition.
