If your bike all of a sudden starts popping or running lean
5 replies to this topic
  • kfrosty
Posted May 21, 2002 - 10:18 AM
I've gotten a lot from this website so I wanted to share something I ran into over the past couple of weeks to hopefully help out others if they run into it.
About a month ago I put a pipe on my bike and shortly afterwards (by coincidence as I've found) my bike start popping on decel and didn't seem to run quite right. Starting it was still good but on the colder mornings it didn't start as well as it had during the winter.
I checked around and it was recommended that I change the needle jet which I did but to no avail. Went to a sand race and the bike just didn't seem on but I didn't want to do any major changes there so I just adapted.
The following Tues while out practicing I stalled in a corner and went to use my hotstart and it wouldn't move. Had only had it on for about 5 rides. Went back to the truck and took it off and it had quite a bit of sand it in and around the plunger which had it obstructed. Cleaned the hotstart out and lubed it up and vola, my bike was back to running like it had been.
Kept an eye on this for the next two weeks and went to a race where the track got soaked. The bike started running sluggishly again. It was kind of cutting out and didn't seem to want to idle good. It was so wet I had thought maybe the air filter had gotten soaked and water had came in past it some how. Changed air filters and didn't notice water and again had to just live with it the rest of the day.
The following Tues, after prepping the bike I went out to practice and noticed the same thing. When I got home that evening I pulled the hot start back off and low and behold there was water in the plunger "tube". Took a paper towel and absorbed it out and drained the bowl on my carb and road Sun and the bike is purring again.
The moral of the story, keep an eye on the hot start chamber and keep it cleaned regularly especially if you are using after market hotstarts with the cables.
The product I have I love but when open up the chamber like this, it introduces a way for debris to creep inside. I've seen some individuals having unexplained problems and wanted to throw this out there as something to check.
  • Shawn_Mc
Posted May 21, 2002 - 10:38 AM
I have a question: Where does the hot start pull its air from? It looked to me like it just pulled it from the upper side of the slide. Which leads me to another question: How did sand get into your hot start chamber in the first place?
  • Hick
Posted May 21, 2002 - 10:46 AM
Shawn, I believe kfrosty may have the external hot start that came on all pre-2000 models. I think they are plumbed to the air boot…
If not, then nevermind :)
  • kfrosty
Posted May 22, 2002 - 02:46 AM
Hey Guys,
This is an aftermarket hotstart. The water and sand as best I could tell came down through the cable housing. No different than dirt and crud that comes down through the throttle and clutch cables. I didn't list any product names or details because as I said, I like the product but it just adds something else to monitor and clean on a regular basis.
  • Hick
Posted May 22, 2002 - 06:32 AM
Oh come on kfrosty!!
So the Motion Pro or Dr. D hot start relocate kit has, in your case, been allowing crud to get into the plunger area, and therefore potentially into your motor.
That is not good, and I’m sure others that have the same unnamed product we are talking about here would like to know about it.
  • kfrosty
Posted May 23, 2002 - 10:12 AM
I know I know but I don't want to start something here with this product because they have been super to me. I figure if I just put the word out, the people who have after market ones will think to check the plunger area more often and think of this if they have unexplainable problems.
Sorry, if it was from a company that hadn't been good to me I would list the name but like I said my post isn't to cause alarm. These designs like I said open the area up to the potential of letting debris in. I'll add, if you have one I would suggest taking it off and seeing if you have a hole in the front of the plunger that allows you to remove the cable from the plunger. I was thinking about trying to silcone that up or something.
  • Hot  36 replies
  • Hot  33 replies
  • 0 replies
