fork oil
4 replies to this topic
  • strack
Posted May 21, 2002 - 09:46 PM
my question is, is there any way to add oil to forks without removing them. I've changed the fork seals on my yz, now my friends wr forks are low on oil due to a leaky fork seal. i told him he should change them but he only wants to add oil to them. We have a ride tommarow so we woul like to get this done as quickly as possible. any input is appriciated.
98 yz400
  • John_Lorenz
Posted May 21, 2002 - 09:55 PM
Drill a 1/2 inch hole in the side just below the cap.
Bubble gum and duct tape should work to seal it up;
Easiest way with out removing the forks is to remove the haggle bars to get to the Caps.....
  • Ga426owner
Posted May 21, 2002 - 11:11 AM
Strack, tell your friend to replace his seals...that is the best way to fix the problem.
Otherwise, unscrew the bleeder screw on top of the cap. Use a scringe in 5cc or 10cc increments to fill -- even though level probably doesn't matter for your buddy's case
  • strack
Posted May 21, 2002 - 03:56 PM
no probably not it will probably just all leak out again, i think he is looking for a quick temp fix but who knows, maybe ill try that drilling a hole and using duct tape :)
  • Mark_Cantrell
Posted May 21, 2002 - 06:05 PM
Go to your local pharmacy. Get a 5mm syringe, sans needle. They will most likely give you one. Use that to put oil down, oh forget it. What GA said.
  • Hot  79 replies
Need help by Goforaride
  • Hot  68 replies
  • 5 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
