Seal Savers issue
2 replies to this topic
  • 450roost
Posted April 22, 2004 - 05:07 AM
After I put them on (the long ones) my suspension is noticeably alot stiffer. I followed the book and things went smooth when putting them on so im not sure what to think.
It called for using lithium grease around the dust seals after cleaning, I was thinking maybe the savers our dragging on the little bit of grease that gets on the fork
Any thoughts.
  • Indy_WR450
Posted April 22, 2004 - 06:14 AM
You only want 3" of seal saver overlaping the fork tube. I just cut the long ones down into 3 pairs approx 4" overall length. You can cable tie them to the outside of the fork and change them once a month. Forks will should not feel any different. :)
  • blue_beast_wins
Posted April 22, 2004 - 11:30 AM
Sounds like your fork alignment may be out of wack.
