Z-Start gap on my 426 at .88"
2 replies to this topic
  • Dano426
Posted April 21, 2004 - 03:58 PM
I install my z-start, but the gap measures .088" its like I am missing two whole plates???? :) I will have to admit this is my first time working on a clutch, but it just doesn't add up. I sent Rekluse an e-mail with no response after 24 hours? ???
Here is what I have install for the clutch pack starting from the top ---- Friction Disk --- Rekluse (.55) Drive Plate --- Stock Drive Plate ---- and then six more fiction disks and drive plates stacked. Is it correct to have the Rekluse and the Stock Drive Plates together? Seems a little odd? Where do I start adding plates and should I add the stock friction plate the directions told me to take out???
The directions also told me to use 7 mounting shims over each stud and other posts here at TT people said they used 9 ??? Any thoughts???
Any help would be greatly appreciated
Thanks
Dan
  • John_Lorenz
Posted April 21, 2004 - 06:13 PM
Have you called Rekluse
Don't wait for Emails Call the tech support line.
.88 is way off
Are you using two gage's 180 degrees apart?
The version 3 zstart says 7 shims use 7 shims, I did this on mine no worries.
If you have followed the directions you would actually start from the first plate and work down word one at a time until you have the correct Install Gap.
I questioned placing the two Plates together as well. Do as the instructions say, the first two plates are the Rekluse supplied plates :)
You should end up with Rekluse Pressure plate, 2 Rekluse steel plates, then a friction plate.
So in general an clutch will have Fiber disk, Steel plate, Fiber disk, and so on in a clutch stack.
Just follow the Directions Verbatim
MAKE SURE YOU USE TWO FEELER GAGES
  • Dano426
Posted April 23, 2004 - 03:47 AM
I talked with Rekluse and the gap problems was my stupid mistake. I did have the preasure plate pushed down enough for the lower assembley "stand offs" (where the bolts go) to push flush with the presure plate. :D
Rekluse did say that having the stock and rekluse steal plates togeather is the correct way to install it on a YZ426. Sounds a little odd, but I will do what the Rekluse Gods tell me. :)
Thanks again for your help
Dan
  • 5 replies
  • Hot  47 replies
  • 10 replies
  • On January 15, 2017
