Hot-Start relocation after Magura Install?
7 replies to this topic
  • fastenuf4u
Posted April 21, 2004 - 08:44 AM
I am planning on getting a Magura Hydro Clutch kit soon but was wondering where and how I could relocate the hot-start lever? I would prefer not to spend another $50 on the Dr. D hot-start relocation kit but I don't know of another option. Thanks for any help.
  • cm67yz
Posted April 21, 2004 - 09:01 AM
You can use the little lever on the magura it's on top.The 426's have one for the decompression.Im sure you can use that for the hot start!!
  • sirthumpalot
Posted April 22, 2004 - 02:06 AM
Neat idea with the hot start, but I don't think it will work. At least not without a special cable. You would need a cable with the hot start plunger attached to one side. Neat idea though! :)
  • vchssrider
Posted April 22, 2004 - 02:08 AM
I used the liitle lever that came with the clutch. It works fine.
  • fastenuf4u
Posted April 22, 2004 - 04:09 AM
vchssrider,
I found out from someone else with a 450 that the Magura kit comes with a lever for the hot-start built in like you said. I can't wait to get it and try it out! Thanks for the info.
  • Indy_WR450
Posted April 22, 2004 - 11:06 AM
Absolutely the magura decomp lever works with the hot start cable. :)
  • sirthumpalot
Posted April 22, 2004 - 02:55 PM
You have to already have a hot-start cable right? I'm thinking in the case of the 426 which has the carb mounted hot start.
  • krotchwaffle
Posted April 23, 2004 - 03:18 AM
do you guys know if the 450 hot start lever that's attached to the top of the clutch perch would work as a 426 decomp lever with the stock decomp cable?
