can you fix a bent radiator?
11 replies to this topic
  • cassious
Posted April 20, 2004 - 04:12 PM
i took a dirt sample and banged up my left radiator pretty bad. It doesnt leak, but I doubt it will do much good cooling the bike...
is there anyway I can pull it straight again without destroying it????
  • robrob
Posted April 20, 2004 - 04:17 PM
I don't think so, but you might as well go ahead and try.
  • meeh350
Posted April 20, 2004 - 04:34 PM
yes you can, i fixed three.... i still have two. None look very healthy but none the less they both work. Ussually they go from being square to a parallelagram... and sometimes twist...
i was gonna try to explain how to straighten them but there are so many possibilities i could be here all night.. tell me how it bent or post a picture and ill give you my suggestions
by the way, ive ran some REALLY bad radiators and my 02 still pulls holeshots in 250B class and never has boiled over in hot weather
  • antman
Posted April 20, 2004 - 07:28 PM
I have a buddy thats really good at fixing them. He uses blocks of wood and soft jaws on a vice and just bangs softly on the outer seams and twists until straight. They can me fixed. Aluminum bends easy. It can be bent back. They look amost new again when he's done.
  • qadsan
Posted April 20, 2004 - 07:31 PM
Check out Mylers Motorcycle Radiator Repair. I've never used them, but I've heard good things about them.
http://www.motorcycleradiators.com/
  • dilyb
Posted April 20, 2004 - 09:47 PM
I HAVE used Mylers and recommend him highly. I bought Devol radiator guards for my '02 and found out one radiator was already bent (purchased used, couldn't have been me!) and the straight guard wouldn't fit! Sent the bent rad. off to Utah and for about $60 total it was back at my door straightened ... and the guard fits. Compared to a new unit, that worked for me. I believe the minimum price is about $40 but this one required more work.
  • meeh350
Posted April 21, 2004 - 03:51 AM
thats pretty much how i do it... just use that to start with.... you have nothing to loose... even had my one welded by a friend. for 60 bucks ill just go buy a new one...
  • pritchard67
Posted April 21, 2004 - 03:57 AM
I riged a 1/4 in. bolt through a dent puller and inserted in the holes on the side of the radiator then banged away.Depends how bad yours is but it is worth a try saved mine. :)
  • mx_361
Posted April 21, 2004 - 04:31 AM
Here is a fix for radiators dented in the side that requires no banging. Just get a 2X4, some saftywire and a long piece of pipe. Place the 2X4 flat against the dented side. Thread the saftey wire through the fins and around the 2x4 and pipe and then turn the pipe while holding the 2X4 straight. It will slowly pull the dent out and if you are carefull it will look and work like new.
  • CrDr
Posted April 21, 2004 - 05:19 AM
you can also bring them to an automotive radiator shop, they can fix them like brand new.
  • cassious
Posted April 21, 2004 - 05:36 AM
  • MikeYarbrough
Posted April 21, 2004 - 05:37 AM
That sounds like a good idea...I'll try that one when I get home. :)
options on swaping a 07 crf450r for a 2003 kx250 by 92rmx250
Dirt Bike   Make / Model Specific   Kawasaki   Kawasaki 2-Stroke
  • Hot  40 replies
2008 CRF450r JB Weld on Crankcase by Sternzy
Dirt Bike   Make / Model Specific   Honda   CRF450R/RX
  • Hot  70 replies
CRF that has been sitting for 6 or 7 years, is that safe to buy? by deanevo
  • Hot  36 replies
crf450r 02 no shims in intake valves but still runs. by BreezyHonda
  • Hot  47 replies
Honda CRF450R 2017 by Chris.GVS
Honda CRF450R 2017
  • 0 reviews
