Lame oil questions.....
3 replies to this topic
  • hvyw8t
Posted April 20, 2004 - 12:16 PM
Help me settle a little dispute. How much oil do you guys put into your bike after an oilchange, without dropping the oil filter?? How often do you clean the screen in the oil line?? Sorry for the lamo ?s. Thanks Big Mark
  • Joe_Jet
Posted April 20, 2004 - 01:01 PM
I change the filter every time. I start off with 1000cc and do the pressure check per the manual, shutdown, check qty and add if needed. I only check the screen after break-in and then maybe every 6th oil change.
Joe :)
  • sirthumpalot
Posted April 20, 2004 - 01:12 PM
It's been dusty so I've been changing every other ride. Drain, add 1.5L, check the filter every couple of changes. I haven't checked the screen in the front tube in a while.
  • aford541
Posted April 21, 2004 - 07:53 PM
On the 450 I put in 1200 and let her ride with a filter change
