426 rear brake carrier on a 450???
2 replies to this topic
  • BVille870
Posted April 20, 2004 - 11:11 AM
will the rear brake assembly off a 426 work on a 450f? I broke a mounting tab off mine sunday racing and i need a replacement or i will have to go ty davis's route. Thanks guys
  • Matt96xr6
Posted April 20, 2004 - 02:51 PM
The 426 uses a different caliper than the 03 450 models. So not unless you get the caliper also.
FYI, the 426 uses a large piston than the 450 caliper.
  • BVille870
Posted April 20, 2004 - 04:03 PM
Thanks matt, I figured the bracket that all of that mounts to was the same. just hope i can find one now.
03 WR450F 160MJ, needle richer 1 clip, wire clipped, air box mod, odo removed, twin air, all blue plastic, long seal savers, yz rear fender, EE handguards, protaper t-clamp+bars, Bridgestone tires, WC frame/radiator guards, CF lower fork guards, CF skidplate. Pro circuit t-4 slip on,DS customs brake fin. Race tech springs on the way, retorqued flywheel nut ,
Wanted Parts: IMS 3.3 or bigger tank (new or slighty used)
