stock oil filters
2 replies to this topic
  • trunkmonkey55
Posted April 20, 2004 - 08:44 AM
I keep hearing about people cleaning there stock oil filters. can you clean your stock oil filter for the 2004 WR450F :)
  • simon@vic
Posted April 20, 2004 - 10:43 AM
the 04 wr450 filter is paper. when you go to replace it buy one for a 2002 wr426. it is stainless steel and you can clean and reuse them about 20-30 times.
if any one tells you you will blow up your motor they are on glue. they are the same size, shape, have the same pressure blow off valve, and they are $1 cheaper the the one time use paper ones.
:) :D :D :D
  • sabin
Posted April 21, 2004 - 09:40 PM
Simon,
I wonder did you tested the valve on the filter? How do you know it is the same pressure blow off valve???
