XR650L chain sprocket questions
No replies to this topic
  • 2wheelsmorefun
Posted April 20, 2004 - 05:22 AM
ADVERTISEMENT
My chain broke when I was riding a couple weeks ago and luckily it
happened in a good place where I could get a replacment fairly
quickly. I bought this used so I am not sure if the chain was stock
or not. The rest of it was modded out so there is a good chance the
chain might be aftermarket. It got me thinking that if I am 50
miles back in the woods somewhere and lose my chain it is going to
be a bad day. I want to get a spare master link just in case.
Unfortunatley the only chain I could get as a replacement that day
was at a yamaha shop from parts unlimited and it was only about $25
and had no o-rings.
1. What is the mfg of the stock chain?
2. It is a 520 chain right? What does that mean exactly?
3. Is the stock chain equiped with a master link?
4. I tried to figure out the make of the chain on mine and all I saw
was a symbol on the links in the shape of an ohm symbol. Anyone
know the make? Not all master links fit the same so I need to
figure out the make.
5. Is a $25 chain that doesn't have o-rings a really cheap chain
that I shouldn't be using? What kind should I get and why?
6. I noticed when I took off the cover for the counter shaft
sprocket that the sprocket moves quite a bit. The 2 bolts are tight
so is this normal. It moved side to side a bit and I know there are
people that had stripped shafts on these. I believe it is the stock
countershaft.
7. What is the stock size countershaft and main sprocket?
Thanks
  • 17 replies
  • Hot  35 replies
Honda XR650L 2016
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
