aftermarket tripple clamp
6 replies to this topic
  • Hamish
Posted April 18, 2004 - 07:00 PM
I just got an aftermarket top clamp similar to this one (so I could move bar mounts forward) Only problem I see is that because the clamp is much taller than stock, (3 clamping bolts instead of 2)when the forks are raised in the clamp by any amount, clamping area is lost due to the taper on the forks. If I was to run the forks level with the top of the clamp the ol' 426 would turn about as well as a road train.
I guess it will be ok as 2 of the 3 clamping bolts are over the correct section of the fork tube. Anyone else had this problem?? If so was it an issue??
  • Matt96xr6
Posted April 18, 2004 - 07:46 PM
Look at how the clamp is built. You cannot have the clamp higher than stock at the center stem nut. If you did, you would have to mill out space for the nut to seat on the threads or make a longer stem.
So where does the extra length go? down!
FYI, the pros dont use 3 bolts in their clamps. To much stiction. Use 2 of the 3 bolts per side.
  • Hamish
Posted April 19, 2004 - 12:04 AM
This bit has got me intrested...
I fail to see how clamping force on the outer fork tubes 3" from the top of the tube could result in extra stiction between the fork legs and the bushings. :)
Anyway I had planed just to use the top bolts, I was just asking if anyone else had run acreoss the same problem.
  • Matt96xr6
Posted April 19, 2004 - 05:03 AM
Dont ask me cause I do not ride at that level. But top and bottom they only use 2 of the 3 bolt holes. My boss at work use to wrench and manage a few of the different pro teams out there.
  • Hamish
Posted April 19, 2004 - 05:42 AM
#5 just curious
  • JVP
Posted April 19, 2004 - 07:51 AM
That is a nice looking Triple Clamp! :)
  • Hamish
Posted April 19, 2004 - 10:37 AM
sure is...and the Serco version that I got is cheap as chips $215 AU (about $160 US)Only difference is that the Serco version doesnt have the clamp on the stem.
