Owners of Hebo hydraulic clutches...
2 replies to this topic
  • motousa
Posted May 15, 2002 - 03:12 PM
Hey ya'll, I jsut got done putting this unit on to my four-two-six....and it doesn't seem to be pulling the clutch actuation arm far enough to engage the clutch completley. Did anyone else have this problem? I thought that adjusting the piston furthere back in the slave I would be able to eliminate this but no luck. Any help please! :)
  • PK
Posted May 16, 2002 - 05:21 AM
Try adjusting the cable where it comes out after the slave cylinder. It sounds like your slave cylinder is maxed out. The slave cylinder should reset itself to a more neutral position once you get the adjustment in the ball park.
PK
02 426
  • MX_Tuner
Posted May 16, 2002 - 06:18 AM
I think PK is right on the money. Either that or adjust the lever stop so the lever goes out farther and adjust the pushrod clearance to compensate for that.
  • Hot  47 replies
  • Hot  36 replies
  • Hot  50 replies
  • 0 replies
