no spray of gass!!
4 replies to this topic
  • tjhenni
Posted April 18, 2004 - 05:14 AM
Just got done cleaning out my Carb. After bolting it back on I'm trying to check the duration of the accell pump spray of gas. I have a BK Mod on my carb. No gas is spraying out at all. Any ideas of what I should check?
  • John_Lorenz
Posted April 18, 2004 - 05:29 AM
If you just took you carb apart I assume all the gas is out of it including from the Pump Diaphragm as well
Two things here
One you either have the GBmod adjusted to not allow a duration
Two You have no gas in the Pump itself
And
Three The Pump Diaphragm is damaged or not working correctly.
I would more say one or two
  • Satch0922
Posted April 18, 2004 - 07:24 AM
John nailed it!
  • tjhenni
Posted April 18, 2004 - 07:43 AM
OK -
I buttoned the bike back up.
Started it - seamed to run good.
Did a could laps around the yard.
Tore the subrame back off
checked for Spray - none??
I've got me BK screw backed out all the way. Would running the bike "prime" gas into the pump? Or do I need to manually "prime" it somehow?
  • John_Lorenz
Posted April 18, 2004 - 03:50 PM
I sent you a few posts from this as well
Check your PM
Just in case
No AP Squirt
  • Hot  50 replies
  • 10 replies
  • Hot  30 replies
  • 0 replies
