No clearance with handguards (lever hits)
5 replies to this topic
  • Redwoods
Posted April 16, 2004 - 10:00 AM
I just bought some tusk d-flex handguards and the clutch lever hits the metal bar, so I moved it down and it hits the plastic, there is not enough clearance for the clutch lever to be operated without touching the guard. Any suggestions?
  • simon@vic
Posted April 16, 2004 - 10:04 AM
maby move the clutch perch in a bit :)
  • mtrablue
Posted April 17, 2004 - 03:37 AM
cut the ball off the end of the lever. if your uncomfortable with the look or feel you can bend the end up a little without it breaking off. the new wr's have a different lever from the yz's so finding a shortie will be tough. some catalogs list them as the same but there not. or go z-start.
  • tp3dxf
Posted April 17, 2004 - 11:15 AM
You might want to look into getting a MSR Raptor clutch lever set up. It has an adjustable pull. Makes the clutch pull lighter or harder if you like, and it has a cool shorty lever with a built in rubber gripper. They are fairly inexpensive as well. About $40 for the whole set up.
  • trailriderjoe
Posted April 18, 2004 - 01:12 AM
I had the same problem with my Bark busters. I had to "Tweek" the bark busters in the vise until everything fit. Still to this day when the weather is really HOT, the clutch levers ball end gets a little sticky on the bark buster (it's really close). The other thing I do is rotate my levers / perches down just under the guard. Food for thought :)
  • Redwoods
Posted April 19, 2004 - 04:35 AM
Thanks, I talked to a mechanic friend of mine and he suggested I move the lever on the bars more to the inside. I did and it worked. It now has clearance. Thanks for the posts.
