Brake fluid
6 replies to this topic
  • sixinchsloth
Posted April 12, 2004 - 04:19 PM
What's the difference between dot 4 and dot 5? I mistakingly ordered dot 5 bel ray synthetic when my bike calls for dot 4. Should I swap it out or will it work ? :D :)
  • OC768
Posted April 12, 2004 - 05:34 PM
I guess tis the season for fluid changes. Assuming you saw this thread already. Ill add to it by saying that if I recall correctly, the Dot5 is more hygroscopic (thus - absorbing water quicker) then Dot 3/4, and would require more frequent changes to maintain consistent performance.
I go with the Dot3 (castrol)GT LMA or BelRay dot 4, both are cheap and available, but the LMA is good for those 3am insomniac visits to walmart :)
  • endurodog
Posted April 12, 2004 - 07:05 PM
I saw a discussion that DOT 5 can be harmful to the rubber seals in some systems. Don't know if this is true or not.
  • YAMAKAZE
Posted April 13, 2004 - 03:25 AM
DOT 5 is just fine if you completely drain the system DRY before adding it. Mixing 4 and 5 together will cause thickining and will ruin the seals on the actuator. I learned that lesson the hard way a while back. If you have mixed them FLUSH YOUR SYSTEM IMMEDIATELY!
Bonzai :)
  • Matt96xr6
Posted April 13, 2004 - 05:04 AM
You have that backwards actually. DOT5 is LESS hygroscopic. It was designed for the military so that it does not absorb water and can be used in a vehicle stored for long periods of time without getting contaminated by water.
  • OC768
Posted April 13, 2004 - 03:44 PM
I go with the Dot3 (castrol)GT LMA or BelRay dot 4, both are cheap and available, but the LMA is good for those 3am insomniac visits to walmart :D
Thanks :) I just know I have a sticky note on my brain to not exceed 4 for any purpose unless it was a new system altogether but I couldn't remember why.
I just know like oil, if you buy cheap - buy often :D
(no, no Rotella ramblings from me today :D )
Thanks for straightening this out guys :D
  • Guest_blatham489_*
Posted April 14, 2004 - 04:30 PM
Ditto on the DOT5 is less hygroscopic. A drawback is that it is actually a compressible fluid, therefore creating a spongy feel in the brakes.
  • 10 replies
  • Hot  50 replies
  • 5 replies
  • 0 replies
