Headlight on/off switch
2 replies to this topic
  • hagen505
Posted April 12, 2004 - 03:29 PM
Hi, I was wondering if anyone has installed a on off switch for their headlight. I have an 04 650L and there are times when I would like to be a bit more stealth, and turn of the light. I was hoping someone could save me some test light time and tell me which color wire to splice into. Thanks.
  • XR650L_Dave
Posted April 12, 2004 - 04:47 PM
It looks like there are 2 single wires to put a switch into, to turn it off if its on hi-beam or low-beam
1 would be the green ground lead right off the headlight bulb.
The other is one going to the hi/low beam switch that is labeled as Bu/W. Some color with a white stripe.
The highbeam wire is the "Bu" colored one.
The lowbeam is the "W" (white) one.
  • Buckarmadillo
Posted April 12, 2004 - 05:17 PM
You have two choices:
1. Switch(as in break the electrical flow) the Green ground wire coming from the headlight itself, this will break the ground circuit for the headlight and open the circuit
2. Switch the Blue/White wire at the dimmer switch control, this will cut power to the headlight before it branches off into High or Low beam power
  • 4 replies
Honda XR650L 2017
  • 0 reviews
  • Hot  35 replies
  • Hot  60 replies
