another wr to yz timing
4 replies to this topic
  • gal
Posted May 07, 2002 - 10:37 AM
when i adjusted my friends 99 wr400 valves i also changed his timing to yz timing. i guess i did it well cause the bike started on first kick . but i want to b sure i did it right - how do u guys count the 12 links , from where to where ? (i counted from the 12 oclock on the exhaust to the 12 oclock on the intake....
and one more thing - what if ill change the timing on my yz 1 tooth clockwise? like on the wr to yz timing , as it on 9,12,3 on both cams....
  • John_Lorenz
Posted May 07, 2002 - 10:50 AM
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOO
DOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOONNNNNNNNNNNNNNNNNN
NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNTT
TTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT
[ May 07, 2002: Message edited by: EgoAhole ]
  • gal
Posted May 07, 2002 - 10:53 AM
iiiiiiiiiiiii
wwwwwwwwoooooooooonnnnnnnnnnnnnttttttttttttt,
bbbbbbbbbuuuuuuuuuutttttttttttt wwwwwwwwwhhhhhhhhhyyyyyyyyyy??????????????
  • John_Lorenz
Posted May 07, 2002 - 11:02 AM
Gal
I posted a simular question, regarding the timeing. The manual says to have the TDC at the [I] with the cam lobs at say 11 oclock 1 oclock
two other manuals I look at say to align the to divits flat with the case Remember Posted Image
Remeber we talked about that.
What I found after talking to a old tuner bud of mine is this
1: Unless you establish the timing of the cams with a degree wheel follow the YZ manual
2: dont worry about the divits being out of place
3: follow the manual (YZ)
the diff is a high and low spot on the cam and the divits. I would not recomend moving the cams at all for the yz....
  • gal
Posted May 07, 2002 - 11:23 AM
okokokokokokok got the idea , wont touch it man .
thanks
  • On January 15, 2017
Motocross
  • Hot  491 replies
  • Hot  36 replies
  • Hot  50 replies
