base valve removal , or using air gun(egoahole)
5 replies to this topic
  • gal
Posted May 06, 2002 - 10:21 PM
i just replaced the fork oil and opened the base valve with airgun and 14 allen bit. the problem is that i can use torque wrench when i tight the base valve back to place , how do u guys tight it to the spec. when u use air gun ? i just tighten it not so tight but not so loose (with feeling) and put a small amount of loctice , any comments?
btw , same thing with the clutch basket nut, when i moved to the p.e billet clutch basket...
  • freestyle111
Posted May 06, 2002 - 10:38 PM
if you put bike in gear and hold rear brake you can use torque wrench on clutch basket.
  • wylie1
Posted May 07, 2002 - 06:04 AM
What fork oil did you use? And what oil height did you use? I have a couple of quarts of mobil 1 ATF I was thinking of using, but now I am not sure. Also I want a softer ride so I assume more oil means stiffer ride and less means softer. Is this right?
[ May 07, 2002: Message edited by: wylie1 ]
  • John_Lorenz
Posted May 07, 2002 - 06:32 AM
Wylie
Use a fork oil not ATF :)
I have used Yamalube .05wt for the price of the yamaha 01 30 bucks I said forget it.
Depending on your wt, plus prefreance I would use the 05 wt, you can spend more money and get 03 or 02.5, but since I am cheep and change oil alot I use yamalube .05.
set the oil hieght right at 300mm ((OPPS :D Imean 130mm)) and decomp at 7 clicks rebound 6
Gal
I have not yet taken the forks apart so I can not advise yet, I believe Motoman has and others :D
[ May 07, 2002: Message edited by: EgoAhole ]
  • gal
Posted May 07, 2002 - 10:47 AM
thanks and i used silkolene 5wt oil , and set the oil level on 130 mm. after u finish the oil replacement u can use a siringe with a hose to add or to remove oil frm the bleeding holes as u like .
  • John_Curea
Posted May 07, 2002 - 10:52 AM
set the oil hieght right at 300mm and decomp at 7 clicks rebound 6
Now that IS interesting.....
Take Care, John
  • Hot  36 replies
  • Hot  28 replies
  • Hot  38 replies
  • Hot  50 replies
