Big dead spot from idle
1 reply to this topic
  • NuTbAg
Posted April 10, 2004 - 01:01 PM
I just need a little help on this. i did install the cam into my 00 426 an now when it's at idle an i go to wack full throttle it has a huge dead spot. it's ok if after it does it i let off an then on again due to now higher rpm's.
  • sirthumpalot
Posted April 10, 2004 - 02:15 PM
My two ideas are 1) Double check your timing, and 2) clean out the carb and AFTER cleaning fiddle with the fuel screw.
