nuetral saftey switch removal
7 replies to this topic
  • BtB22
Posted April 09, 2004 - 11:11 AM
has anybody taken off the neutral saftey switch instead of just removing the blue or grey wire??? if so what happens???
  • YZFan
Posted April 09, 2004 - 11:20 AM
do a search on the topic you should find all you need.
  • 426_Texan
Posted April 09, 2004 - 11:36 AM
replace it with this
  • Boostn
Posted April 09, 2004 - 12:42 PM
yep, I removed mine since I broke it :D Oh well, replaced it with that cover. Its nice. Also one less wiring mess to deal with :)
  • Matt96xr6
Posted April 09, 2004 - 05:30 PM
What happens?
Same thing as disconnecting the wires! But you lose about .5-1 pound in the process!
  • Rick_Kienle
Posted April 09, 2004 - 08:15 PM
Removing the neutral switch only disconnects the blue wire. You still have to disconnect the gray wire at the harness near the CDI. You get one less gaggle of wires (in which only the blue wire is functional), a little weight loss, and a trick looking plug instead.
  • revolucien
Posted April 11, 2004 - 07:56 AM
cool link, thanx. the full removal rather than cutting a wire and replacement with something cool is enough incentive to go do it
  • Satch0922
Posted April 11, 2004 - 10:25 AM
Dr. D siteglass
