Help with universal brake light switch
4 replies to this topic
  • kolarchi
Posted April 06, 2004 - 07:07 PM
I am trying to install a spring universal brake light switch on my WR400 and have no idea what I am doing.
Can anyone help me out with some advice?
  • DOGBITE
Posted April 07, 2004 - 07:58 AM
I'm not sure if it will work on yours ,but I used a hydraulic brake light switch. Good luck with the spring type ,there is no good way and you will break it first ride. :)
  • WR_Hoss
Posted April 07, 2004 - 10:36 AM
I just installed a hydraulic brake switch yesterday on my 450. It took about 20 minutes and cost 16.95. You just screw it in in place of your banjo bolt. I tied into the wires under the seat - connect one to the blue, one to the yellow. Worked great for me. The stock bulb is dual filament. I wouldn't mess with the spring unit as easy/cheap as the hydraulic is.
  • RichBaker
Posted April 07, 2004 - 10:59 AM
I used safety wire to attach it to the frame, and to the brake pedal. Drilled a hole for the wire in the pedal arm and it was good to go....
Wiring it is easy, I used the battery + for hot, and ran the other wire to the bulb...be sure to fuse it if you do this! That way, the brake light works whether the engine's running or not......
  • stevedon
Posted April 10, 2004 - 08:44 PM
ive also fitted a hydralic switch is so much easier and its mainainence free
