On/Off switch and YZ number plate
3 replies to this topic
  • AkRider
Posted April 06, 2004 - 06:36 PM
I used the search mode but did not find much info on where to relocate the On/Off switch to. The plate fits fine with a little modification but I am not sure where to put the switch. Thanks :)
  • dubious
Posted April 06, 2004 - 07:46 PM
I modified the braket and put the on/off switch on my acerbis hand gaurd mount.
I drilled and tapped a hole in the hand guard mount , and bolted my swtch on there!
I straightened out the angle in the braket on my vice, drilled a new hole in it and ground off the excess metal.
Make sure you position it so roost or looping out won't wreck your switch!
The switch braket is available as a separate piece from Yamaha, if you ever decide to go back to stock. :)
  • weemer
Posted April 07, 2004 - 02:47 AM
I just used the bracket it is mounted on, and mounted it on one of the rear handle bar bolts.
  • AkRider
Posted April 07, 2004 - 07:31 PM
Thanks, that worked pretty well. I had to file the bracket a bit but it looks good and is out of the way. Once the bar pad was on it almost looks like it could be stock. :)
