Servicing 426 forks, anything I should know?
15 replies to this topic
  • Guest_BrandonV_*
Posted April 05, 2004 - 08:57 AM
I am going to service the forks on my 2000 426 this week. I want to replace the fork oil, replace the seals and put the stock springs back in.
I dont have a manual to work from, but I'm sure I'm up to the task.
My only questions are:
-do I need any special tools to accomplish what I mentioned above? (replace oil, seals and springs)
-in what order should I (or must I) tackle this in. I know the oil will go in last, but beyond the obvious, what should I know?
-Any recomendations on brand and weight of oil? I'm about 220# with gear and am an aggressive trail/desert rider.
Thanks.
  • flyinguitars
Posted April 05, 2004 - 10:13 AM
Loosen the caps while the forks are still on the bike.
Back out rebound clicker all the way and count clicks and record
When you pull/push the spring down, You'll need a 17mm open end wrench to remove the caps from the threaded rod...(sorry cant remember what it really called).
take the springs out
remove the nut on the threaded rod
take the white plastic piece out
pump the fork several times and dump the oil
pry the dust cover off with a screwdriver very carefully
pop the retaining clip out of the groove (holds the fork seal in)
pull the tubes apart...you can slide them in and out a few time till they pop apart
take the retaining metal piece off of the inner fork tube
Take the slide metal, washer, seal, and dust cover off.
clean everything
install:
Put a piece of plastic over the top of the inner fork tube and lube it with fork oil (to protect the rubber seal from the sharp edge of the tube...you'll see!)...Ive been using ENZO 01 weight with great results.
slide the dust cover, seal, washer, and slide metal on
put the retaining metal piece back on the top of the inner tube
Get your seal driver (make one from 2" pvc pipe...go to motomans site for directions) and seat the slide metal and washer into the groove of the outer tube....
seat you seal with the driver
pop the retaining ring in
seat your dust cover
turn over and compress fork fully
fill to top with oil
pump inner rod more than 10 times with 5" or so strokes...go go too far or you'll suck air
fill fork again...do over
fill fork again and pump outer tube more than 10 times but not further that 5 or so inches
let stand for about 1/2 hour to let bubbles escape
set oil height (i think stock height is 130mm) im 205-210lbs and I set mine at 115mm to help bottoming
reinstall fork innards in opposite order and dont forget to re-set your rebound
Mike
  • Guest_BrandonV_*
Posted April 05, 2004 - 10:31 AM
Wow! Thank you.
that about covers it......
  • 426F
Posted April 05, 2004 - 12:14 PM
I was wanting to do the same thing to my bike but I wasn't sure the technical difficulty of performing this task. I can do about anything to my bike but have not messed with suspensions at all. Also I printed off the manual in motoman's website so I have a parts break down. How would you rate the difficulty of this task?
  • CAL
Posted April 05, 2004 - 12:37 PM
It's easy. On a scale of 1 to 10, I'd rate it at a 5. First time may take a little while, but after knowing what you're doing, it should take about an hour per fork tube total when changing seals. Just a fluid change...about 30 minutes per fork tube.
  • 426F
Posted April 05, 2004 - 12:58 PM
Thanks for the reply Cal. I think that I will give it a go. I got quoted $125 from the local Pro Action guy so I think it will be worth it to try it myself. Thanks Again.
  • vetplus40
Posted April 05, 2004 - 03:02 PM
If you don't have a bonified syphoning tool to remove new fork oil if you overfill the tubes, a regular spray bottle nozzle work real well.It will remove very small amounts of fluid allowing a pretty precise measurement.
  • CAL
Posted April 06, 2004 - 02:19 AM
Yeah, don't buy a suspension suringe. I bought a large suringe for $2.00 at a local CO-OP store. Works great.
  • mx426
Posted April 06, 2004 - 02:41 AM
Is it necessary to remove the bottom valve assembly when replacing the seals? I don't have a 14mm hex drive. (allen wrench)
  • CAL
Posted April 06, 2004 - 02:46 AM
Nope.
  • Mike88
Posted April 06, 2004 - 06:38 AM
OK, I know this has been covered in other threads, but what other oil brand/weights do you guys run. Thanks.
  • XXX_Thumper
Posted April 06, 2004 - 06:59 AM
Here is the manual Downloadable Manuals - FREE
Also, I made a sort of a guide for my 450. This may help. My STEP BY STEP GUIDE
  • Guest_BrandonV_*
Posted April 06, 2004 - 07:05 AM
Thank you! that is very nice.
To your knowledge is there any difference between changing seals on the 450 or 426?
Mike88,
I've mostly been reccomended to use Enzo 01 or Yamaha's 01 fluid. I've been told Enzo is very similiar to the Yamaha brand (or even the same) for less $$.
  • CAL
Posted April 06, 2004 - 07:28 AM
In my 426 forks I ran synthetic Mobil 1 ATF (7.5w) as per Jeremy Wilkey's suggestions (MXTech). In my KTM I'm running Honda 5w oil.
  • SXP
Posted April 06, 2004 - 08:56 AM
How did the forks feel with the ATF relative to say 5w oil?
  • CAL
Posted April 06, 2004 - 09:14 AM
I never did a switch from 5w to ATF. But I've gone from stock oil to ATF in two diff. 426's and like the ATF much better. The forks seemed more consitent through the stroke with the ATF. I would have used ATF in my KTM, but when I revalved them, the suggestion was 5w oil. I think I'm going to revalve my forks again and use ATF this time.
  • Hot  113 replies
  • 5 replies
  • Hot  50 replies
  • Hot  36 replies
