switch
4 replies to this topic
  • surfcat2000
Posted April 04, 2004 - 12:56 PM
Just put a JD jeting kit in my friends WR426 and I was wondering what the switch mounted near the top of the carb on the choke side is. It is attached to the throttle shaft and bolts on with 2 allen screws with tits in the middle of the recess and it's adjustable. thanks
  • gfergtr74
Posted April 04, 2004 - 01:48 PM
TPS. Throttle position sensor
  • surfcat2000
Posted April 04, 2004 - 06:58 PM
thanks, what does the throttle position sensor do? and what are the side effects if I don't have it adjusted right.
  • RichBaker
Posted April 05, 2004 - 08:29 AM
It's a potentiometer.....varies the resistance with throttle opening. The CDI uses it to determine the ignition advance setting.
  • surfcat2000
Posted April 05, 2004 - 09:04 AM
thanks
