Sub frame wear
2 replies to this topic
  • w_ahhh450
Posted April 04, 2004 - 01:01 AM
Anyone else have wear from the chain on the rear subframe.
Me and a mate I ride with gave got what seems to be excessive side movement of the chain. He has put another piece of steel, stainlees I think.But if I go for a fix I'll probably try a bit of alloy.
Went for a ride today and was very wet and muddy and I think the chain is totalled.Have a new Regina X-ring chain and supersprox sprockets to go on soon.And a new rear tyre? I'm goin to try the new Michelin ac10 I hope it works well in the mud and sand.
  • lipskid
Posted April 04, 2004 - 05:52 AM
Yeah, when the chain gets a bit loose, they do that. Mine's getting chewed up pretty bad. Thanks for reminding me, I need to get something on there to protect it. :)
  • Ronnie Mac
Posted April 04, 2004 - 06:15 PM
My chain slapped really bad against the sub frame, so I ajusted the slack to spec and put a 1/8 inch piece of rubber under my chain guide at the swing-arm. You have to lossen the allen bolts that hold it on. Cut to fit a 6"or so piece, tighten it down and it shou :thumbsup:ld work. Good luck.
