Front sprocket leak
5 replies to this topic
  • scorch
Posted April 03, 2004 - 01:43 PM
I posted this on xr650r yahoo groups. But a ride ago, i lost alot of oil during a ride. I checked the front sprocket where the oil was driping, and the little rubber around the rod was out a bit. I pushed it back with a screwdriver and it seemed okay.
Now its leaking a little bit, but not much. Im not sure where its coming from now. Cant be the rubber cause it doesnt look ripped or damaged in anyway.
  • stonewall
Posted April 03, 2004 - 03:57 PM
Sounds like a leaking countershaft seal. It's a fairly common problem and an easy fix. Cheap too.
Countershaft seal part # 91205-MBN-672
Here's a link
  • Moredesert
Posted April 03, 2004 - 08:18 PM
That is a problem on the earlier XR650R's. I carry a spare seal and the tools to change it. In fact I just changed mine last week when I had the sprocket off. Picked up another for the back pack.
I wouldn't ride the bike if it's leaking. Just change it. If the seal pops back out you can cook your motor in no time with no oil. :)
  • scorch
Posted April 04, 2004 - 01:21 PM
Basically all I have to do is take the sprocket out, then that little thingy that holds the seal, and with some needle nose pliers just grab the rubber seal?
  • irondude
Posted April 04, 2004 - 04:32 PM
yep-thats it. 10 minutes and you are good to go...
  • scorch
Posted April 05, 2004 - 03:40 PM
thanx doods :)
  • 17 replies
  • Hot  35 replies
  • 22 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 3 replies
