WR426 vs YZ426 what exactly is the difference???
2 replies to this topic
  • CrazyRonny
Posted December 08, 2000 - 06:36 AM
What exactly is the difference between the YZ & the WR???? I want to put one off this bike on the street, but I also want to continue to do MX for fun with it....
I actually own a YZ426 and I jump a lot with it, I ant to know if the WR suspension setup is good for jumping.
And if semeone know how much Watt is generate by the WR426 stator.... To know if I can put street lighning without to much modification...
And what's the other difference in the engine, exhaust, transmission, etc.
You're help will be very apreciate...
Thank's
CrazyRonny
  • MN_Kevin
Posted December 08, 2000 - 08:32 AM
YZ: stiffer suspension, tighter transmission & lower overall top speed, different steering angle, better ergo's (seat/tank), 19" rear tire, less smog crap on carb and airbox, better top end performance.
You can buy an aftermarket lighting system w/ stator/rotor.
'99 WZ with all YZ mods, FMF PowerBomb header, Stroker SX-1 silencer, SS front brake line, forked over by Pro-Action, OEM YZ tank and IMS seat.
  • Team_Oatmeal_Pie
Posted December 10, 2000 - 09:17 AM
you know 426, 427 what ever it takes to get the job done.
