VALVE ADJUSTMENT - NEED YOUR ADVICE
8 replies to this topic
  • gal
Posted April 22, 2002 - 04:03 AM
I WANT TO KNOW IF U GUYS ADVICE ME TO ADJUST MY VALVES BY MY SELF OR GO TO THE MECHANIC. MY MECHANICAL EXPIRIENCE IS AS FOLLOWS:
I ALWAYS DO REGULAR SERVICES BY MY SELF
I CHANGED FORK OIL BY MY SELF
I INSTALLED TY DAVIS FLYWHEEL WEIGHT
I CHECKED VALVE CLEARENCE ONCE ( LAST SUNDAY)
AND ALL THE SMALL THINGS THAT ALL US DO (BK MODE , FILTERS ETC.)
DO U THINK I CAN DO IT ONLY FROM THE MANUAL AND FROM THE POSTS IN T.T ???
  • John_Lorenz
Posted April 22, 2002 - 04:11 AM
Gal
You can do it !! :)
If you have done all of the work yourself so far dont stop. With the gang here you will save yourself plenty of bucks, as well as gain a vast knowledge of your bike.
  • #302
Posted April 22, 2002 - 05:29 AM
If you don't have them already get the shop manual,a 3/8 torque wrench that reads 8lbs and a quality assemble lube, and take your time. :)
  • gal
Posted April 22, 2002 - 07:03 AM
i have a torque wrench that reads 12-60nm, how important is the to close the cams bolts on 10nm and the tensioner bolt on 7nm?
  • John_Lorenz
Posted April 22, 2002 - 07:19 AM
Its important to stay in spec on any eng torque spec. I am not sure the conversion from nm to ftlbs,
Anyone :)
Sounds like you have to heavy a torque wrench
[ April 22, 2002: Message edited by: EgoAhole ]
  • bassr_#186
Posted April 22, 2002 - 10:17 AM
Another bit of advice: mark the timing chain and the cam gears before disassembly so that you don't have to fumble around on reassembly trying to play connect the dots.
  • jamracing
Posted April 22, 2002 - 10:31 AM
For the first time, I would put a zip-tie around the cam chain and intake cam sprocket, since it will be staying on the bike. You can also call me with any questions. Got a web-cam? :)
  • gal
Posted April 24, 2002 - 11:10 PM
thanks jamracing
ill call u and i have a digital cam so ill take pics , but not live ones...
  • Boit
Posted April 25, 2002 - 07:18 PM
bassr, that's the same advice I've been giving for ages. How do you mark your cam sprockets in relation to the chain? I make a small "V" mark with an engraving bit in my Dremel tool on the side of the chain plate above each sprocket's punch mark. Talk about making things so much easier!
  • Hot  30 replies
  • Hot  50 replies
  • Hot  28 replies
  • 10 replies
  • On January 15, 2017
