Torque wrench.......Tools?
5 replies to this topic
  • wylie1
Posted April 21, 2002 - 12:40 PM
I was reading on another post and it was mentioned not to go cheap on a torque wrench. This makes alot of since, and I think that putting a little more money in good tools is alot better than not going riding because I have to stay home and fix a stripped bolt. On the other hand, I do not really want spend the money on the (Snap-On) name. I have one of those cheap torque wrenches, that I am going to replace ASAP and I was thinking about getting one of the 3/8" drive Husky torque wrenches from Home Depot. So what brand torque wrench would you guys recommend? And is there any other tools that we should not go cheap on?
[ April 21, 2002: Message edited by: wylie1 ]
  • cowboyona426
Posted April 21, 2002 - 01:46 PM
Just about any torque wrench with a dial on the handle that twists to the appropriate measurement, not the needle type, from a quality tool store should be fine. The Husky one from Home Depot is probably okay. You really shouldn't go cheap on any tools, especially specialty tools like spanner wrenches etc. A few more dollars spent on a tool is a lot better to me than stripped or broken parts on my bike.
  • Pazzo_P
Posted April 21, 2002 - 02:42 PM
I'd spend a few $ more and pick up a Craftsman "Digitork", it's easier to set and read, plus I'm pretty sure when needed it can be sent back and recalibrated.
  • mxcowboy
Posted April 21, 2002 - 04:12 PM
Craftsman about $90 I think, because you break a socket with a impact they replace it with no questions asked try to find a snap-on dealer at 6:00 on a saturday or anyday for that matter.....
  • sirthumpalot
Posted April 22, 2002 - 12:41 AM
I personally like craftsman. I have some husky sockets and after breaking 2 in a row trying to remove a stuck bolt on a friends car, we bought a craftsman to replace the broken sockets and it took the bolt right off. I've got craftsman torque wrenches and they have been fine for me so far. I'm weary of the accuracy of models that cover a hudge range so I got 2 wrenches, one for smaller bolts (up to about 29Nm) and one for larger bolts (over 32Nm). They are the dial type (I agree to avoid the needle type, almost impossible to be accurate). I got them on sale for about $60/ea if I remember correctly. Here are the lables if this helps:
[ April 22, 2002: Message edited by: sirthumpalot ]
  • YZ400Court
Posted April 22, 2002 - 05:04 AM
Selecting the Correct Torque Range— For the most accurate performance, the maximum torque you're applying should fall near the middle of the tool's torque range. For example, if you're applying 50 ft.-lbs. of torque, it would be better to choose a wrench with a range of 5 to 100 ft.-lbs., rather than a range of 5 to 50 ft.-lbs.
Accuracy— Accuracy is usually given for 20-100% of a tool's torque range. For example, if the torque range is 20 to 120 in.-lbs., the accuracy statement is true for measurements between 40 and 120 in.-lbs. Below 20% of the torque range, the tool's accuracy often drops off significantly.
Click type:
Wrenches signal when torque setting is reached with an audible "click", an impulse in the grip, and a momentary release. Accuracy, for 20-100% of torque range, is ±4% of the torque setting for clockwise use and ±6% of the torque setting for counterclockwise use
Round-Beam Torque Wrenches :
Round-beam wrenches offer an economical way to measure torque. Wrench is steel with a plastic grip that pivots and transmits torque directly to the indicator needle for a precise reading. Dial has a diecast metal base plate and shows units in in.-lbs and cm-kg, or ft.-lbs. and m-kg. Wrenches torque clockwise and counterclockwise; accuracy is ±4% of torque reading for 20-100% of torque range
Flat Beam:
Flat-beam wrenches are the most accurate nonelectronic torque tool. They have few moving parts, so there's less friction and maintenance. Memory pointers show the maximum torque reached. The grip pivots to concentrate the load at a precise point on the lever; this ensures torque accuracy when adapters and extensions are used. Accuracy is ±2% of torque reading for 20-100% of torque range
All above from the following web pages. http://www.mcmaster..../html/2602.html
  • Hot  38 replies
  • Hot  47 replies
  • Hot  36 replies
  • On January 15, 2017
  • Hot  30 replies
