Panoram/Endurance computer getting wet?
8 replies to this topic
  • Portland_650R
Posted March 30, 2004 - 10:29 AM
Mine faded after a rain ride. Anyone else have this problem - and a solution? I was thinking about putting plastic wrap over it when I know it will be really wet.
  • sunnymex
Posted March 31, 2004 - 04:28 PM
I would suggest that you take it off your bike and throw it in the trash. I know it sounds pessimistic, but I am not a fan. I went through 3 of them in about as many months. The mounting slides kept breaking. A buddy of mine also broke 2 of them.
I never had a problem with it getting wet, but then again, it does not rain too often down here. Try silicone or maybe the plastic wrap will also work.
Good luck.
  • motart
Posted April 01, 2004 - 05:06 AM
yep, my buddy's mounting tabs broke and the computer went sailing down the road. so i took mine off and sure enough it was starting to break, too. coincindentally, it stopped working all together a couple days ago because the insides rattled apart :D :) :D
  • sunnymex
Posted April 01, 2004 - 09:44 AM
Yeah, I am sure that there are many others who have encountered the same problem. Did you ever figure out a way to makeit better or at least to keep it from breaking. I strapped on a zip tye and that worked for a while , but it was harder to read the numbers under that and it also looked uglier than sin.
Anyhow...such is life with crap products like that. I just ordered another type of speedo I will let you all know how it works as soon as I get is.
  • Lencho
Posted April 01, 2004 - 09:52 AM
Chuckle. When I first arrived in La Paz, I started putting in underground conduit for network cabling between buildings and was a little concerned that they were building the tops of the underground wiring vaults too close to grade. "Don't worry," I was told, "it never rains here." Well, OK, they're the natives.
Needless to say, the first hurricane that came through dumped an incredible amount of water on the place in an eyeblink and all our vaults became swimming pools. Sigh. They now extend several inches above grade.
True, it doesn't rain here... very often, that is. :)
  • Portland_650R
Posted April 02, 2004 - 03:11 PM
I went to Trail Tech's website, got 15% off on another one (out of warranty). I ride my BRP to work, so I need to have an idea about how fast I'm going (actually the Max Speed feature is the best part!) I WILL try plastic wrap next time though. Thanks! :)
  • AzMtnThumper
Posted April 02, 2004 - 08:43 PM
This is an interesting speedo setup: cateye speedo
  • micmecroberto
Posted April 02, 2004 - 09:32 PM
I buy in motorcycle shop the motorcycle dashboards (90.00), but after the buy, the salesman show me the billet mounting
bracket protector (30.00), this solve the problem only add
flexible mounting (grommets),and use clear tape to protec it from dust
  • HairyScary
Posted April 03, 2004 - 10:06 PM
I made a bracket out of 1mm(?) thick aluminum plate. You can see it at:
The curved edge and the length between the bar bolts have rolled edges
to add a bit of structure. To bolt their bracket flat to a plate, you
have to either shave off the excess of the toothed wheel (for their clamp
on bracket) that hangs below the surface, or put a spacer between the unit
and the mounting plate (I did the former). It is tucked in out of the way
of damage. I thought of using the original 6mm mounting holes in the top
clamp that were for the stock odometer, but that put it down too low and
made the cross bar interfere with visibility.
Oh, and I didn't like the idea of slicing and gluing the hyd. brake line
guide hoops, so I cut their wire about 6" from the unit and added a small
plug there. The wires are fine, but can be soldered to etc. I taped the
off-cut of a cable tie parallel to the wire and across the plug to ensure
the wires didn't flex too much and break where they were soldered to the
plug. This also makes sure the plug doesn't un-plug.
